How to set different triggers by model time using different distributions?
wgranizo
wgranizo
[ FlexSim 22.2.2 ]
Hi! I want to set a token creation by time of the model. I have 3 different distributions and times to set as trigger. For example, one distribution is for 8:00 to 14:00.
jonah_kendellR47TC
I would recommend using the Date Time Source to plan your token arrivals. Under "Edit Arrivals" you can change all the options you need - set the repeat interval to daily, set your time windows in the table, and set the appropriate distributions in the "Offset / Variability" edit box.
andrew_o2
Hi @William Glp, was Jonah K's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
