how to set a travel time between each process?
BaraM
BaraM
[ FlexSim 24.0.0 ]
how to set a travel time between each process? such as between source and queue? or between queue and processor? and so on.
moehlmann_fe
The easiest way to set a precise travel time would be to use network nodes and define a virtual distance that results in the wanted travel time when taking into account the speed of the task executer that will do the transport.
Note that the virtual distance for the connection from A to B is set independently from the connection from B to A. So make sure to adjust the value at both network nodes.
custom-path-distance.fsm
BaraM
Thanks for your time and responses, but actually I don't have distance nor speed. I only have the travel time for instance 15 s between the queue and the processor. I couldn't find anything that will help me yet.1.jpg
moehlmann_fe
This exercise looks more suited to be build in Process Flow. Maybe take a look at the Basics Tutorial. I deals with a similar situation.
https://docs.flexsim.com/en/24.2/Tutorials/FlexSimBasics/BasicsOverview/BasicsOverview.html
BaraM
I see. Thank you so much.
