How to set a discharge order?
Rodrigo_23
Rodrigo_23
[ FlexSim 23.1.3 ]
i'm trying to set a discharge order to a transporter, i tried shortest by distance but it keep skiping some discharge points.
natalie_white
Hi @Rodrigo Vázquez ,
It's hard to know how to help without looking at your model. To receive a more accurate solution, please post your model or a sample model that demonstrates your question.
If your model contains sensitive information, you could first toggle your post as private using the "make private" option under your question's "gear" menu. Private questions are visible only to site moderators. You can also contact your local FlexSim distributor for phone or email help.
jason_lightfootVL7B4
You need to upload the model or tell us how you're creating the tasks.
Is it done as single tasks in a process flow or is it using standard "Use Transport" task sequences on the fixed resources? Is there another dispatcher in between the two?
If you can't upload your full model then try building a test/example model that you can share.
Jeanette_Fullmer
Hi @Rodrigo Vázquez , was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
