How to send to port by Using Global Lookup Table
dan_here
dan_here
[ FlexSim 18.1.2 ]
I am trying to send to port by Using Global Lookup Table, but Is not working
Simulación del puerto 5.1.fsm
julio_r
Hello Dan,
First, I see that you have modify the lookuptable function directly in the name of the table.
If you want to read the table Datoos de entrada with the row item.RowNumber and column 6 you need to set up the option as in the image.
Second, I tried runing with this configuration and it seems like the Row number of some item are bigger than the number of rows in your table of Datos de entrada.
Please let me know if this is what you are trying to do or if it is something different.
ryan_c10
Hi @Dan Here, was Julio R's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
