- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
[ FlexSim 20.0.2 ]
When I simulate using Experimenter Run, I can obtain a Raw Data table with all scenarios and the result of a variable for each replication in that scenario. However, when I run the Optimizer Run window to search for the best solution, the table that I can export is a table of means of replications, it doesn't give the result for each replication, it only reports the mean of all replications.
So, my questions are:
1) How do I obtain the table with all replication's results that FlexSim has done during the optimization run?
2) How do I select the optimal scenario? Sometimes there are lots of points and I select using the mouse a good scenario but not the optimal. Is there a way to do it?
Thank you!
