How to resume the item once the item flow arrives a decision point?
alejandro_ulises_tp
alejandro_ulises_tp
[ FlexSim 18.1.1 ]
presentacion-run-test-ac2.fsmIm having trouble with the decision points, i want to resume the item flow waiting at DP1 once the item flows arrive at DP4 or DP5, anyone know how to do it?
joshua_s
Here's your model with some changes to it. It looked like you were trying to do round robin sending in the first place, so I connected DP2 and DP3 to DP1, then had it send items round robin. I added a different process flow and disconnected your other one to see if the changes I made are what you wanted. Hope this works for you.
12850-presentacion-run-test-ac2.fsm
alejandro_ulises_tp
Actually I wasn't triying to round robin, i was trying to send the item once it arrived at DP4 and DP5, i think i need to change the WaitForEvent parameter
jose_antonio_mad
Hello @Alejandro Ulises TP,
I attached a model. I added a "Decide" and then another wait for event.
I hope I have been helpful.
isaac_l1
Did this help answer your question?
