How to replace the GIS map
supportPHJ4A
supportPHJ4A
[ FlexSim 22.2.0 ]
Hi, guys,
I deleted all the tile maps in the GIS, and then opened the map, it will automatically generate a tile map according to the location you moved to, I don’t know if it can be replaced, then I put After the address of the Server URL is changed to the download address of the Baidu Map tile map, the tile map automatically generated by it cannot be opened.
I would like to know why the tile map generated after changing the address cannot be opened, and how to change the GIS map, whether to change the server, and if so, can it be changed, and how?
philboboADSK
When changing the server address, you should also change the Tile File Prefix so that it saves and loads tile files with different names than the default tile file names.
See GIS Navigator (flexsim.com):
Tile File Prefix
Specify an optional prefix to be added to tile filenames when saved on the hard drive.
Use different prefixes to distinguish between tiles when using different tile styles from different tile servers.
For example:
If the server is returning black images, that's a different problem entirely. Verify that the server you are contacting at the specified address is returning valid image files.
Phil BoBo
Sr. Manager, Software Development
supportPHJ4A
thank you very much,it works.
