How to repeat a certain experimenter run
chao_gao
chao_gao
[ FlexSim 16.2.0 ]
In the experimenter, when you do different scenarios test and each scenarios you run multiple replications, then you get a min and max value out of all the replications, how would I be able to repeat a certain run (say the run that lead to min value) in the 3D window?
JordanLJohnson
First, save your model (as a different file name, for backup). Then, on the Scenarios tab of the Experimenter, use the Choose default reset scenario dropdown menu to choose the scenario you would like to use. To replicate a specific scenario, go to the Advanced tab on the Experimenter and use the Repeat Streams of Replication box to choose a replication number. Then reset and run your model.
The easiest way to get your model back to its original state after doing this is to load the backup file.
Jordan Johnson
Principal Software Engineer
chao_gao
Thanks, this is exactly what I am looking for.
