How to re-import table from excel on reset?
jarek_o
jarek_o
I have a 'parameter' global table that has to be updated during runtime. But when I reset my model the numbers have to go back to default. Is there an elegant way to do this (not with on reset triggers and stuff...) Thanks
SCHamoen
@Jarek O If you excel changes there is a checkbox you can use on Excel Import gui, but that is a bit slow and if your excel hasn't change this doesn't work. The simplest solution in my opinion would be to have the same excel file read in to 2 tables and in the onReset triggers simply copy one table to the other. The code is very simple:
Table table1 = reftable("GlobalTable1");
Table table2 = reftable("GlobalTable2");
table1.cloneTo(table2);
A second option would be to use the excelimporttable command in the onreset trigger.
( you said you didn't want to use the reset trigger but I don't see any other way of doing it without writing any code)
jarek_o
Thanks, I will clone the table.
