How to programmatically execute FlexSim model?
ranjith_tellis
ranjith_tellis
[ FlexSim HC 5.3.4 ]
I want to execute a FlexSim HC model (.fsm) file programmatically by providing it Patient Arrivals as input.
The FlexSim model (.fsm) contains experiment variables and all the necessary inputs like Process time, Staff/Resource schedules etc. embedded and the model is also configured to create the output files.
I want to invoke the FlexSim exe file programmatically to run the model/experiment by passing it the model file (.fsm) and the Patient Arrival appointment time (.csv). Once the execution is complete, I would expect the Output files to be generated in the respective directory from which I will extract the statistics and build some plots.
Any suggestions on how to execute the model programmatically?
Ranjith
tanner_p
Here is a thread containing code samples that can be used to execute different commands upon start-up. Take a look at this and then let us know if you have additional or specific questions.
https://answers.flexsim.com/questions/21116/automatically-configure-and-run-a-flexsim-model.html
Reference the section on "Command Line Options" specifically.
ranjith_tellis
Thank you, that's exactly what I was looking for.
