How to point to a item inside a container from a list?
daniel_saravia
daniel_saravia
[ FlexSim 22.0.0 ]
I have PF called "Granite Process" where a pallet with an item t is staged on a queue. The pallets inside the queue are sent to a list ("Granite Jobs"). I am having problems trying to load only the item (box) with a crane in my process flow I don't know how to address it. When I pull the token from the list I assign token.cart. then I have to move the pallet to a another queue then load only the item (box). I have another PF called "Raptor Process" where I was able to make it work. Thanks!
OM Countertops Parctice 7_autosave.fsm
joerg_vogel_HsH
If it is a global list you can add a field which evaluates the subnodes of your pallet (list value as an array value.subnodes.toArray()). If you explicitly pull your field name from your list you get the array as a pull result. Then you can address your items from your pallet from this array.
But you can do the same if you pull just the pallet from your list and let it stay on it. Then you can evaluate the subnodes of your pulled pallet reference and use the subnodes for your task.
If you want to identify empty pallets on your list, then add a field which evaluates dynamically the value.subnodes.length. You can pull empty pallets from your list.
https://docs.flexsim.com/en/22.0/ConnectingFlows/Lists/WorkingWithLists/#fields
