How to move item after specified time
maciej_c4
maciej_c4
[ FlexSim 20.2.3 ]
I have a following problem:
On the source I have an items which are move from Queue to Rack by employees. Next, the other employee moves items from Rack to 'Received Parcels' but I would like to Operator5 has certain time to pick up each item (for example 1 hour). It means that if any item spend more time than 1 hour in the rack should be automatically moved to 'Missed Parcels'
Could anyone help with this? Because I have no idea how to solve it
Model: https://drive.google.com/file/d/1ajjNOu8BZCn9JeUqFnabkbKCRDjPSDB_/view?usp=sharing
Thank you,
Maciej
Jeanette_Fullmer
Hello @Maciej C4,
You can do this easily in process flow. I created an event triggered source that creates a token when an item arrives in the rack. Then a wait for activity for when the item leaves the rack followed by a sink. This activity also has a max wait timer of 1 hour. If that max wait timer is triggered then the token is released to the move object activity and it is moved to missed parcels queue.
Model Link
maciej_c4
Thank you for explanation!
Maciej
