How to make the Operator pull the flow item from truck
vineeth_n
vineeth_n
[ FlexSim 19.1.1 ]
rack-model.fsmHow to make the operator pull the profile from the conveyor while loading on truck.
Currently the operator is rotating with the profile during loading.
Please suggest me how to carry on with the simulation.
Thank You.
braydn_t
Hey @Vineeth N
These changes aren't perfect, but they look a little better. Let me know if they work for you. If you need more help, feel free to tag @Braydn T in your reply.
First, select Operator2 and de-select the rotate while travelling box:
Then remove the Unload task from your Process Flow, and add a Change Visual, Travel, and Move Object tasks so your Process Flow looks like this:
Here is what the Change Visual's Properties looks like:
Here is the Travel:
And here is the Move Object:
I hope this helps!
vineeth_n
Thank You @Bradyn T , my model is now working good, I have deselected rotate for the operator2 and I used travel for unloading the profile in queue.
Here I have attached my model, please find the same.rack-model.fsm
aiw
