How to make the Mercurius Inc. process flow work?
jose_abraham_b
jose_abraham_b
[ FlexSim 20.1.3 ]
Hello, @jeff.nordgren
I want the operator 3 to grab a tote from queue #4 which has the type of box and the order number located in the tote. Furthermore, the operator grabs it and takes it to the combiner, but I want the operator to go to the rack and have him grab the box that the tote is asking for that specific type and that's where it gets stuck. It only takes the totes to the combiner and it doesn't go any further than that. How can this issue be solved or fixed? The attached document "Racks with Process Flow" is the one I am trying to work out, the "totes racking" is the one I am trying to make it look like process flow wise.
Any help will be really appreciated.
Thanks in advance. @jeff.nordgren
Sincerely, Abraham
Racks with Process Flow.fsm
totes racking.fsm
jeff_nordgren
Hi @José Abraham B,
A description of the problem is valuable information but it's hard to know how to help you without looking at your model. To receive a more accurate solution, please post your model or a sample model that demonstrates your question.
Proprietary models can be posted as a private question visible only to FlexSim U.S. support staff. You can also contact your local FlexSim distributor for phone or email help.
Thanks.
jeff_nordgren
@José Abraham B,
Attached is your model with the few minor changes that I made.
The problem is, when a token gets to the Jala de la lista process flow block it stops. Why, one reason is your List Reference is invalid. I tried using your global list "Pedido" without any luck. And nothing ever gets "posted" to that list. So the process stops there because it can't pull anything off an empty list.
You had some other errors with invalid names but I think I fixed those. One field I can't find where it is defined is the "Ubicacion". You are trying to use that but I don't know where it's coming from.
Anyway, if you could give us more information on how the model is supposed to work, that would be great.
Thanks.
racks-with-process-flow-JN.fsm
Ben_WilsonADSK
Hi @José Abraham B, was Jeff Nordgren's answer helpful? If so, please click the red "Accept" button on their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
