How to make rotate a imported flow item and make it move across processor
dhakshinamoorthy_a
dhakshinamoorthy_a
[ FlexSim 19.0.0 ]
Hi
I am facing a trouble where i import a model as a object and after crossing a processor i would want it to change shape and make the changed shape pass by the processor. I would like to rotate the shape which would make it to pass through the processor length. The shape is a model of a train, which reduces the size which i don't want to happen.
27685-1587978699982.pngI Have added a second image of how i want it to be passing through the processor. Attached below.27676-1587978846006.png
I have attached the Flexsim model and model of the train below
Model 1.fsm
metro-coach-shell-1.snapshot.1.zip
braydn_t
@Dhakshinamoorthy A
This can be done in the on entry trigger of the processor. You can play with the size there.
updated shape.fsm
regan_blackett
These trigger options I think give you what you are looking for
dhakshinamoorthy_a
Okay @Braydn T Thank you for your input.
dhakshinamoorthy_a
Thank you @Regan Blackett for your answer..
