How to make operator use pallet or taskexecuter from source and move to sink?
dhakshinamoorthy_a
dhakshinamoorthy_a
How can make operator to use the taskexecuter.
where as in my case it is the operator has to use the taskexecuter which is the pallet to move the objects from the source to queue. @Ben Wilson I have seen your video on where the operator and taskexecuter pick the objects from the combiner. Can you help me out?
tanner_p
Hi @Dhakshinamoorthy A,
I've created an example model that uses an operator with a "cart" (Task Executor) to load/unload boxes. Your question was kind of vague, but I'm assuming this is what you're expecting in terms of a response. I also took the liberty of creating this model in 19.1 because you didn't specify a version.
To achieve the effect that an operator is using a "cart" to transport objects, there are two main things that you need to do:
1) Use Travel and Move Object activities in Process Flow rather than Load and Unload activities.
2) Move the "cart" object into the Operator object.
The key is accurately placing the Boxes inside the 1st subnode of the Operator, which is the "cart". This model uses labels extensively, so let me know if anything with labeling is unclear and I'll try to better explain it.
Hopefully this helps!
Model: make-operator-use-taskexecuter.fsm
braydn_t
@Dhakshinamoorthy A
Did Tanner's answer work for you? If so, could you click the accept button? Thanks!
larissa_r2
hi @tanner.p, i tried to use the same logic.
I am desingning a warehouse. I have 5 placers, and 5 carts. I need the placer to grab the cart, go to the queue, load products an the place then in the racks.
When i try to use your logic, flexsim shows: 'time: 0.000000 exception: Error: Invalid destination at move object activity "Move Cart into Operator" in "ProcessFlow"'
How can i fix this? Can you help me please?20produtos-vs3.fsm
braydn_t
Hi @Larissa R2
Please follow our Best Practices and post this in a new question.
Thank you!
dhakshinamoorthy_a
Thank you for your solutions @tanner.p . It was quite helpful thanks a ton.
