how to make folklift works just when transporter is stopped?
kevin_teodoro
kevin_teodoro
[ FlexSim 16.2.0 ]
By Default, the transporter lift the folk while it is moving. I would like it just do this when it arrives the correct bay and then the folk starts to lift to the level.
rodrigo_lamas
Please see the network nodes in the attached model, the folk stated just after pass the last node in the transporter way. model.fsm I hope that my comments can be helpfull for you! Best Regards.
joerg_vogel_HsH
The forklift rise is part of the offset travel. If you use pickoffsettask or placeoffsettask as a tasktype in the tasksequence you are able to set the ratio of the coordinate movement individually. Maybe you have to use the tasktypes more than once to limit the whole transporter action.
kevin_teodoro
I understand, but I still have difficult with the parameters of pickoffsettask and placeoffsettask. Could you help me? Could you give me some example?
Thank you very much
jing_chen
Hi Kevin. Here is an example from old forum (Sorry for forgetting the original modeler). I have modified it for fitting what you want and may it will help you.
rack-placeoffsetv16.fsm
kevin_teodoro
This example helped me a lot, but this is just for unload, could help me with the load proccess too?
Thank u
kevin_teodoro
I got it! Thank everybody
