How to make FIFO in crane
andre_t6
andre_t6
[ FlexSim 21.2.2 ]
Hi everyone,
I have a problem with FIFO with a crane. Here is how my model should have been work.
1. At time 0, queue 2 and queue 3 will be full of box, so the crane will be moving the box to queue 5.
2. When another box arrive in queue 1, the crane should be moving the box from queue 1 to queue 4 until the queue 4 full and didnt send it to queue 2 or 3 because it will destroy the FIFO system (the item in queue 4 should be full first so that the box from queue 1 can be send to queue 2 and 3)
But my model likely send the box to the shortest distance, like queue 2 and queue 3 when there are space in there.
Could anyone help me in this problem
Semi-FIFO Model.fsm
ryan_c10
Hello @Andre T6,
I was able to accomplish your desired objective by removing the trigger on Queue1 to set the Destination and doing that in process flow instead. The flow I have checks to see if the item being pulled is originating from Queue1, then determines which queue to send it to based on a comparison between the current content and the max content of Queue4 (prioritizing Queue4 if it still has space, then choosing randomly between Queue2 and Queue3 if Queue4 is full).
I hope this helps! Let us know if you have further questions!
andre_t6
Hello @Ryan Clark,
How do i set the trigger in the process flow?
ryan_c10
Hi @Andre T6,
The way I did it was using a custom code to set the destination based on the criteria I mentioned previously. Here's a modified version of your model with that change made: crane-fifo-rc.fsm
andre_t6
@Ryan Clark thanks for fixing my model.
