how to make AGV stop at non-control point
jiang_j
jiang_j
[ FlexSim 18.0.9 ]
Hi, i want to built an industry-train model by AGV module , the train may be need to stop at anywhere of the network, so i need the AGV stop at non-control point,What should I do?
thanks
tanner_p
Hi @jiang J
I think I understand that you will have something triggering your train to stop. If that's correct, please review the following:
You can use Custom Code activities in Process Flow to stop and resume the AGVs. There is a pick list option for Stop Object that you can use to sample the AGV in your system. I'm not sure how your train system is set up, but hopefully this simple example will give you the concepts you need to make this work in your model. Let us know if you would like additional support. Thanks!
Example: stop-agv.fsm
isaac_l1
Hi @jiang J
Does Tanner's reply help answer your question? If so, please click the Accept button below the answer.
Thanks!
