How to make 3D structure in Flexsim?
hhnaing2
Message 1 of 8
hhnaing2
[ FlexSim 23.1.1 ]
I saw this image from one of the question asked by someone. May I know how I can drawing this kind of drawing? Was in drawn in FlexSim or 3rd party software? If it is, could you please advise the software name and file extension of the drawing?
So far I tried to make one .stl drawing in Solidworks. It is one piece so I cannot make different color on different area of the part. Thanks.
Replies (7)
Message 2 of 8
FelixMoehlmann
When you switch to the healthcare environment (button in the top right corner of the screen), this object is found in the Prop category.
After adding it to the model you can switch back to the regular environment. You can also see the file path were the file for the shape is saved in its properties.
You an apply this shape to other objects by copying over the path (or choosing the file from the explorer)
Message 3 of 8
jason_lightfoot_adsk
In this case the shape has been saved in AC3D format (*.ac) but it may have been created in something else.
Message 4 of 8
hhnaing2
Hi Jason, Would you mind to recommend any software that can produce AC3D format.ac based on your experience? Thanks a lot.
Message 5 of 8
Message 6 of 8
hhnaing2
Thanks, Jason. Support from Flexsim team is awesome!
Message 7 of 8
Note that if it's just colors you want to change you can do that by editing the mesh directly in FlexSim.
Message 8 of 8
hhnaing2
Thanks.
