[ FlexSim 19.0.0 ]
Is it possible to link a combobox in a dashboard to a global variable?
When I only link the combobox to the variable it does not work.
Can I make this work, or do I need to add an extra node in the tree where I will link the combobox to.
The combobox will be the only place where the global variable is changed.
Thank you in advance,
Patrick
(A small example model: combotest.fsm )
