How to let processor to contain only one pallet?
wendy_l2
Message 1 of 8
wendy_l2
[ FlexSim 21.2.4 ]
Hi, I have two questions at below.
1. I hope a processor only contains and processes only one pallet, so I set up processor Max Content = 1. Unfortunately, I found there are two pallets in processor at same time.
2. I found that the last pallet can't ship to queue2 and AGV is waiting in front of Processor 2_2. How can I let AGV ship the last pallet to Queue2 and on the assumption, if AGV task finish and no pallet to ship, all AGVs will wait in front of Processor2_2 and Processor2.
Thanks for anyone answering my question.
PickingProcess_Ver3.fsm
Replies (7)
Message 2 of 8
jason_lightfoot_adsk
It's because your unload station is set to "by percentage" - you should use token.processor.
Message 3 of 8
wendy_l2
Could you explain more? How to use token processor? Thanks!!
Message 4 of 8
In the station field of the unload task activity enter:
token.processor
Message 5 of 8
wendy_l2
Thanks! Could your help solve the second questions? The last pallet is still on AGV and dose not ship to queue2.
Message 6 of 8
It's because AGV1 is at Queue2's control point - it won't be deallocated until it reaches another control point or leaves that one (depending on the setting).
A simple fix is to add a travel task to a park or waiting location after the unload.
Message 7 of 8
In the attached model I add a trigger for onResourceAvailable to have each AGV travel to a control point near the pickup.
pickingprocess-ver3_jl.fsm
Message 8 of 8
wendy_l2
Thank you so much!
