How to insert an equation to create dashboard?
Dghd_65
Dghd_65
[ FlexSim 24.0.3 ]
How to deal with following situation?
1. If the Efficiency is given by following equation, how to get it to the dashboard?
Efficiency = Ideal Time / Actual Production Hours
Ideal time = ideal time of all the processors
2. If we want to get sum of ideal times of 2 processors or multiple processors to the dashboard, how to get that. How to get a sum?
moehlmann_fe
Observer
Observer
Dashboard charts display the data stored in either Statistics Collectors or Calculated Tables. To display the your efficiency stat, you need to calculate/store it in either of these two options.
Attached is a simple example model. The process time for each item is written as a label to the items. This label is then used by the processors to determine the process time. Once a process finish, the item is also added to a global table cell that keeps track of the total processing time of the processors. (You can get this value in other ways but this should hopefully be easy to follow).
A Calculated Table then uses the data from that table to calculate an efficiency value by dividing the total processing time by the model time.
calculated-table-example-fm.fsm
logan_gold
Hi @Dinusha_98, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
