How to import data from HTML file.
anutt_k
anutt_k
[ FlexSim 22.1.1 ]
Hello. I have question about data importation.
If I have some data in html file like this picture.
How can I import this data into FlexSim. Or I should transfer data to Excel and import from Excel import tool.
Or this can import from some other solution.
Thank You.
LongG
In my view :Call python in Flexim, use python code to process these and return values to implement import.
SCHamoen
@Anutt K If the content of the file is as simple as you show I would use the File commands for instance fileopen and filereadline
anutt_k
Thank You. Now I found once solution. I use additional tool as webpage in connectivity then I import html code of some webpage from develop mode of browser into webpage code editing.
anutt_k
OK Thank You. Now I found once solution. I use additional tool as webpage in connectivity then I import html code of some webpage from develop mode of browser into webpage code editing.
