How to implement C++ toggled node?
mischa_spelt
Advisor Advisor
mischa_spelt
[ FlexSim 18.1.2 ]
Are there any pointers on how to create a C++-toggled node that will execute a member function on a module object? I wanted to 'override' an eventfunction which is called through function_s so I created a C++ toggled node with contents
c->asObject(MyClassName)->MyMethodName();
but though FlexSim did not complain it did not call any C++ code either. I tried toggling the node as regular FlexScript and putting in a msg() to make sure it does get called. Any tips?
philboboADSK
Try
o(MyClassName,c).MyMethodName();
Also, if you are trying to call a method on a class defined in your module DLL, you should probably toggle the node as DLL and put it in your DLL instead of C++ compiled into flexsimcontent.dll.
Also, from a C++ toggled node, your MyClassName might be ModuleName::MyClassName because the code isn't in your module's namespace.
Phil BoBo
Sr. Manager, Software Development
mischa_spelt
Thanks Phil, I was hoping to bind directly to my class method, but I guess a global function coupled to a DLL-toggled node is still the way to go.
