How to implement AGV entry/exit rotating platform
Ian5
Message 1 of 8
Ian5
[ FlexSim 20.2.3 ]
In my case, the AGV uses a special steering method that requires a rotating platform to achieve steering. The AGV enters the rotating platform along the path and stops, the rotating platform rotates 90° with the AGV, and then the AGV leaves the rotating platform and continues along the following path
Replies (7)
Message 2 of 8
supportPHJ4A
You can use kinematics.agv_plane_rotV23.2.fsm
Message 3 of 8
Ian5
my Software Version is Flexsim 2020 not 2023
Message 4 of 8
Jeanette_Fullmer
Hello @Ian, You can download 24.0 from our website and open the model in that version. You will be able to see how the sample model was created.
Message 5 of 8
Ian5
@CSN Thank you very much for your answer, I am curious about how to use script commands to achieve, I tried to write a few commands, found that it can not be achieved, if you can help will be very grateful ,thanks .
Message 6 of 8
Jeanette_Fullmer
Hello @CSN ,
Would you be able to help with this further?
Message 7 of 8
supportPHJ4A
Kinematics (flexsim.com)
In the model, I use kinematic PF. So you can use kinematic script.
Message 8 of 8
Jeanette_Fullmer
Hi @ian, was CSN's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
