how to get the output variable of a queue ?
mohamed_slama
mohamed_slama
In my model I need the value of the output of the queue during my simulation.
Can someone helps me to get this value with a code ? Something like 'getvarnum'...
Thank you
joerg_vogel_HsH
int output = getoutput(node Queue); // node Queue is the reference to your queue-object
int output = getoutput(model().find("Queue100")); // if you use the find method.
joerg_vogel_HsH
It is even simplier, if you use the sampler tool (Icon of an eye dropper). Then you move this tool over the Queue and click the left mouse button. You choose from the opening window the entry "Getters..." and then the appropriate line of code.
@Mohamed Slama
Matthew_Gillespie
As @Jörg Vogel shows in his comment, the Object class has a stats property that lets you access a bunch of statistical values that the object keeps track of. To get the output it looks like this:
Object obj = model().find("Queue1");
int output = obj.stats.output.value;
Matthew Gillespie
FlexSim Software Developer
