How to get the agv state information using custom code ?
athodupunoori
athodupunoori
[ FlexSim 21.1.5 ]
I used process flow to determine the operation of an AGV such as travel, load, unload. I would like to know what is the state of an AGV using custom code so that i can decide where my token needs to go next.
For example as seen in the attached image, the selected AGV is blocked. i would like to check that using the custom code in decide function.
jason_lightfoot_adsk
If you agvs are members of an object process flow then the state can be found using:
current.stats.state().valueString   //returns eg.  "idle"
or
current.stats.state().value   //returns eg.  1  or STATE_IDLE
Otherwise substitute current with a pointer to your agv object - eg token.agv
