how to get part of label from another label
raashid_mohammed1
raashid_mohammed1
[ FlexSim 16.1.0 ]
What is the code I have to write to pull only the object part of the label
For example I have label - item /object/Value
I want to get only object out of the label called item above
so other label should give me label - DockName - object
Please help see below token
Matthew_Gillespie
I'm a little confused by your question, but looking at the values in the table I can see that the item label has a reference to the OAK5-NIGHT object inside the Dock20 object.
To get the OAK5-NIGHT object you'd just use the getlabel command:
treenode obj = getlabel(token, "item");
Matthew Gillespie
FlexSim Software Developer
raashid_mohammed1
So item = /Dock20/OAK5-NIGHT
I want DockName value to be just /Dock20
Matthew_Gillespie
//Get the referenced object
//Get the object that contains the referenced object
treenode parent = up(obj);
//Set the DockName label to have a reference to the parent object
setlabel(token, "DockName", parent);
Or in a single line:
setlabel(token, "DockName", up(getlabel(token, "item")));
Matthew Gillespie
matt_long
Using an Assign Labels activity it would look like this:
