How to get items flow into different processors?
yi_jing_l
yi_jing_l
[ FlexSim 17.1.6 ]
type2fsm.fsmHi there,
How can I get the items go into different processors?
In the picture attached, the items are only flowing into one processor and causing bottlenecks.
Appreciate very much for your help.
mason_w
Hi @Yi Jing L,
The answer you're looking for is using a decision point, but there are several use cases for them depending on the logic you want to point items to a specific processor. I'd recommend you work through the conveyors tutorial found in FlexSim. It guides you through how to use decision points pretty well.
Find it at Guide > Tutorials > Additional Tools Tutorials > Tutorial 1 Conveyors > 1.1 - Sorting Systems
Hope this is helpful!
aravind_d
Hi @Yi Jing L,
I have a built a similar model for your reference. I have created different item types and color for your easy understanding.
keeping a decision point in the conveyor and adding the correct trigger helps to transport different item types to flow in different processors as per your request.
flexsim-answer.fsm
ThankYou.
raja_sekaran
@Yi Jing L
You can use round robin method in the decision point to send items to different conveyor lane. I have reattached your model with changes.
Hope this is useful.
Thanks.
conveyordecisionpoint-support.fsm
yi_jing_l
Thank you very much! :')
yi_jing_l
yi_jing_l
