Hi @olivier T,
Please find attached a sample model (entry-and-exit-times-for-1-processor.fsm😞
The Statistics Collector listens to 2 events on the Processor:
For both events, I renamed the label name of the entering / exiting simply as item:
This label name is then used in the Data Recording tab to create unique rows for each item:
The Object and EntryTime columns are updated when a new row is added in the statistic collector:
And the ExitTime column is updated by event dependency:
This column's data is updated only when On Exit is fired:
As a bonus, I attach another sample model (entry-and-exit-times-for-a-group-of-processors.fsm) if you want to to track the entry and exit times for a group of processors:
Hope this helps.
