how to get a report from simulation model by periode for each replication?
handi93
handi93
[ FlexSim 24.1.0 ]
for example, i run the simulation of production in some company for 1 month as 1 replication and i will get the output each month. but i want to know the output production each day in the simulation from every replication because i need this data for validate and compare with real sistem.
moehlmann_fe
Observer
Observer
If you use the Experimenter to run different scenarios/replications, the dashboard data for all replications will be saved to an sqlite database file and can later be viewed and/or exported.
https://docs.flexsim.com/en/24.1/Reference/Tools/Experimenter/Experimenter.html#advanced
handi93
but if i do that, i just get the report by scenarios/replications.
the problem is i want to get the information of report each periode
for example the simulation is running 1 month (that is one replication) and i want to get the report output data for each day just like how many output in day 1, day 2 etc.
moehlmann_fe
Observer
Observer
You can use an "Output by Hour" chart (which, despite its name, can also be set to measure the output in other intervals).
You can view both the respective chart as well as the data behind it for each scenario/replication in the experiment results.
logan_gold
Hi @handi dharmawan, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
