How to fix the plane to the floor
hf_96
hf_96
[ FlexSim 19.0.0 ]
I would like to be able to fix the anchor the plane to the floor in a way that, the components of the model can be moved except the plane.
pierre_gauly
You can put an object in another one (for example a Queue in a Plane) by following those steps :
1 : Open Edit Selected Object
2 : Select the master object (the Plane in my example) with left click + CTRL. The object will be highlited in red.
3 : Left click on the object you want to put in the Plane (the Queue here). The object will be highlited in yellow.
4 : Click here :
Now, if you move your Plane, the Queue will follow.
If you don't want to be able to move your Queue, you can right click on the Queue to "protect" it :
Note : You also can press ALT when you're moving in the 3D view. It will ignore all the objects while you're pressing ALT.
Thillaiarasu
How to ungroup this ? if needed
jason_lightfoot_adsk
Move them into the model.
