How to find the exact line number of error?
asb_praneeth
asb_praneeth
[ FlexSim 17.0.11 ]
While running the model due to null pointer references model is trowing exception errors in system console. While throwing errors it is not specifying line number where this error is happening.
Is there any why to find the exact line number where is error is happening?
axel_kohonen
Hi @asb.praneeth
I am not sure if you can get a line number, but as the error comes from UserEvent1 as the error says you should be able to put a break point at the beginning of the user event and then step forward in the code until you get to the line that gives the error.
Hope this helps!
