How to dynamically change column width of GUI Table
KSugai
KSugai
[ FlexSim 23.0.11 ]
I want to change column width of a GUI table when a string that is too long to fit in a cell is written to the table.
I added subnodes to the cellwidth attribute, and I am changing the value of them under "VIEW:/active" during simulation. However, they are not reflected in the displayed table.
Also, There is no change even if I run "repaintall()" command.
If there is a way to dynamically change column width of GUI Table, please let me know.
jason_lightfootVL7B4
You should use repaintview where the view is the table view:
eg:
treenode view=node("VIEW:/active/GUI 12651353864/table2");  // path to the active table view in a test model.
cellwidth(view).subnodes[3].value=20;  //width of column 3
repaintview(view);
