How to determine the distribution based on given values
priyanka_g
priyanka_g
[ FlexSim 20.0.10 ]
Hello, I want to know which statistical distribution should be used as per the given data below:
MTTR = 5 mins & MTBF = 200 mins
these are the only data i have to determine the distribution, how to choose the distribution?
jason_lightfootVL7B4
https://en.wikipedia.org/wiki/Failure_rate
If you don't know anything other than observations are independent, then you could use negative exponential. Since this is memoryless, you can also use it for the first observation.
If you know the min and max values then you could try to approximate a shape by reverting to triangular or looking for a distribution by matching shape visually.
priyanka_g
Is negative exponential same for both MTTR and MTBF?
What do you mean by the same? If you decide to use that for both they will of course be the same type but each will have a different parameter since the means are different (5mins and 20 mins).
Jeanette_Fullmer
Hi @mary,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
