how to create the flowitem with itemtype when 'Create Flowitem' trigger option
SimFlex_support
Advisor Advisor
SimFlex_support
[ FlexSim 17.0.3 ]
A model has about five hundred types of flowitem in the global type.
I will use 'Create Flowitem' in OnMessage of Source or Queue object.
But the trigger script of 'Create Flowitem' has only the quantity and Flowitem Bin rank.
I am using only rank 1 of 'Box' and want to transfer or set one type of five hundreds.
How can I do it?
I need help.
rodrigo_lamas
@david.seo maybe try to use another queue trigger, on entry / data / set itemtype and colour options, for example in order to define your itemtype when you receive the message, maybe you can use a percentage, a label or a globaltable information to create your rules. Regards.
jeff_nordgren
@david.seo
Attached is a sample model of how you can assign an itemtype to flowitems that you create in a queue. The modified code for doing that is in the OnMessage trigger of the queue.
createflowitemsfromq-jn1.fsm
SimFlex_support
Dear @Jeff Nordgren
Creation item by Send Message Trigger is not possible in the case of the remote sending message. What's the reason?
event-pull-from-list-test-v201703-09-3.fsm
I attached the sample model.
This is related to the issue below.
https://answers.flexsim.com/questions/36462/when-many-queues-want-the-flow-items-to-move-from.html
SimFlex_support
I tried it from remote queue to the first queue to send message with direct center-link or script find command. But it is not applied, why?
I added the sample model.
SimFlex_support
Dear @Jeff Nordgren and @Rodrigo Lamas.
I got it.
I found a bug in my script. My model is OK.
I attach my model.
event-pull-from-list-test-v201703-091.fsm
SimFlex_support
event-pull-from-list-test-v201703-091-2.fsm
I fix the above model bug.
moveobject() call deleted OnMessage trigger.
