How to create shipments of products (Como crear cargamentos de productos)
Gonzaaaasm
Gonzaaaasm
[ FlexSim 22.2.3 ]
Hello, how can I create a shipment with products inside , which follow a type of uniform distribution (2,6), hopefully with process Flow. I leave a piece of the statement
Hola, como puedo crear un cargamentos con productos dentro , que siguen un tipo de distribución uniforme (2,6), ojalá con process Flow. Dejo un trozo del enunciado img-20221124-090548.jpg
sebastian_canas9DYX7
Hi @Gonzalo Salazar,
I remind you the FlexSim's Policy on Academic Integrity. As it's said in the article, you could start giving a look at the tutorials, then trying yourself to build the logic searching deeper in this site (I'm pretty sure someone has already asked something similar) and finally, if you have at least a demo model, you can follow the best practices and ask for guidance.
Some tips I give you to start with:
  • Understand what is the logic of a model.
  • Labels are an important tool you would need to use.
  • Using Triggers one can set or edit information within a Label.
  • Empirical Distribution could come in handy
  • Understand how to use the probability distribution you have
andrew_o2
Hi @Gonzalo Salazar , was Sebastián Cañas's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
