how to create different quantities of a product in a source
ismael_r3
ismael_r3
[ FlexSim 21.0.0 ]
I need a source to create a distribution of products, that is, I do not need a product to be created at the same time, but different amounts. I have a distribution of the quantities, how can I make that happen in the source or in some other place. Greetings, help please. If you can send a model, with an example, it would help a lot
yogesh_h
Hi @ Ismael R3 ArrivalSchedule.fsm Please refer the attached sample model
You can do it in the Source. You have to create "Arrival Style : Arrival Schedule" and use "edit table" to create arrival schedule with different time, quantity and labels also if required.
ismael_r3
Thank you but the problem it is that I need a inter arrival style , that do not produce one quantity , it has to produce more than that but with a inter arrival style
lucas_antonio_r2
Hi Ismael,
I guess you can use the option "Values by case" in the inter-arrival option on the Source tab. Then, you can set different statistical distributions. I hope it workis.
Best regards,
Lucas
Ben_WilsonADSK
Hi @Ismael R3,
You can have an interarrival time source that produces variable quantities by combining a source with a separator.
If you have the separator immediately after the source, and set the process time to 0, and split the item into the quantity of items desired, whether according to a distribution, a table, or whatever, then you've effectively achieved your desired outcome.
Please see the attached sample model.
source-different-quantities.fsm
