How to create AGV CP with a cross sign in code?
962076751
962076751
[ FlexSim 19.0.0 ]
37885-001.png Hi you there!
As the photo shown above, CP2, the one that i dragged from the library and put it on the path, is connected with the path with a cross sign inside its shape. And we can see the connection through the tree structure.
Then i attempted to create a CP1 in code like the script below, but there is no connection between the CP1 and the path.
So i wonder how to build the connection between the CP1 and the path through code?
jason_lightfoot_adsk
Call use function_s to call finalizeSpatialChanges:
function_s(cp,"finalizeSpatialChanges");
Thank you, Jason!
Furthermore, function_s() is a powerful funtion you brilliant guys build. As i have searched the manual with nothing found, I wonder where to find the fields like "finalizeSpatialChanges" and their instructions.
It's not officially supported so putting it in a user command might be a good idea in order to change it in one place.
joerg_vogel_HsH
You find undocumented functions in the library tree.
OK! I found it as a DLL node.
