How to create a tool change time?
remi_a2
remi_a2
[ FlexSim 21.2.0 ]
Hello, I have to realize a tool change on the same process which have to be done only once and at the beginning while changing 2 articles. Do you have any idea of how I can do this? Thanks.
ralf_gruber
Remi,
if you are using the Processor object to model your process, you can find an picklist option "If Item Label Value Changes" in "Setup Time", which does exactly what you ask for. Just make the article# a label.
Good luck
remi_a2
Thank you so much, you really did answer my question !
