How to Create a Cumulative Time Plot with Statistics Collector in FlexSim?
mm_ighiri
mm_ighiri
Hi everyone,
I’m currently working on a FlexSim model where I use a Statistics Collector to track the tonnage transported every time a resource is used.
I’ve successfully collected the data including timestamps, and the table looks like this:
DateTime | Tonnage | Tonnage_Mng
02/06/2025 04:50:24 | 10000 |
02/06/2025 07:57:35 | 10000 |
02/06/2025 08:16:57 | 10000 |
07/07/2025 10:18:53 | 0 | 36.40
07/07/2025 10:38:23 | 0 | 54.60
Now, I want to generate a cumulative plot of the tonnage over time — something like a running total that increases as new data points are added :
02/06/2025 07:57:35 | 20000 |
02/06/2025 08:16:57 | 30000 |
07/07/2025 10:38:23 | 0 | 91
I tried using the "increment data" option, but it only works when staying on the same row, which doesn't fit my use case where each data point is on a new row.
I also attempted to use custom code, but I couldn’t figure out how to access the value from the previous row (n-1) to calculate the cumulative total.
Has anyone faced a similar challenge or knows how to solve this ?
Thank you in advance
moehlmann_fe
"collector.getValue(data.rowNum-1, data.colNum)" will get you the value from the previous row in the same column. You then just need to add a case for the first row where only the tonnage value is used.
(In general you can get data from a Statistics Collector table with the same syntax that is used for global tables)
mm_ighiri
Thank you! That works perfectly
