How to convert string type?
KJH
KJH
[ FlexSim 23.2.2 ]
I made a label as "mylabel" that shows location of the current flowitem
I've tried to convert this label to the form of string using valule.getpath(), but the old place comes up.
It's there wrong?
sebastian_canas9DYX7
@KJH ,
What if you try:
Object involved = current.last.name
If you want to get the name of the object, that syntax should do.
logan_gold
This works, except you'll want to use it for the line with value:
Variant value = current.name;
KJH
Thank you! How can I write the label value to the process flow as well? Only this label has a different value.
@KJH,
Could you send the code of Process Flow?
