How to control the quantity of the parts on conveyor
shelly_l3
shelly_l3
[ FlexSim 20.0.3 ]
braydn_t
@shelly L3 It will be hard to give you the best help without your model, but I would use process flow and zones. You can set up a zone for each conveyor, and zones allow you to limit the quantity in them. You could also achieve similar behavior with lists.
philboboADSK
You can use the Slug Builder property on a Conveyor Type to build slugs of parts going down together based on a specific item count. See the attached model. slug-builder-item-count.fsm
If the conveyor type is non-accumulating, then the slug will build up at the beginning of the conveyor before being released. If the conveyor type is accumulating, then the slug will build up at the end of the conveyor before being released.
Phil BoBo
Sr. Manager, Software Development
benjamin_w2
Hi @shelly L3
Was Phil's answer helpful for you? If so, can you please click accept? If not, how else can we help?
shelly_l3
Thanks phil.bobo. I will look into it.
shelly_l3
Yes. Thanks for Phil's help.
