How to control Robot Pick in ABAB Sequence
jared_t
jared_t
[ FlexSim 18.0.3 ]
Hi, I'm new to Flexsim hence if possible kindly teach with example. Thank you.
Currently i will need to build up a layout where picking and placing is through robot. There will be 2 different products infeed (example, Carton A and Carton B). From what i understand, i should be using the model 'combiner' to stack cartons together. But however i will need the sequence to be A,B,A,B order. The current setup i have is either in A,A,B,B order or B,B,A,A which is not what i need.
joshua_s
Here's an example, hope this helps.pick-and-place-abab.fsm
