How to Connect Elevator and Robot in Process Flow
yi_jing_l
yi_jing_l
[ FlexSim 18.2.2 ]
1.fsm
15982-picture1.pngHi there,
How to connect elevator and robot for transferring the flow item to the multiprocessor? I wanted to get the flow item to be transported by the robot to the multiprocessor, after it has been elevated.
Besides, as seen from the picture attached, the flowitem is seen to be floating on the elevator. How to solve this?
Thank you
gilbert_jerald
@Gideon
As per your question I have altered your model in which item will be transferred by the robot to multiprocessors after it has been elevated.
Note: I have used a queue name called"First Floor" in the elevator travel path, The queue is kept at the height where the robot is placed and the queue is been hidden. This is done to see visually that the item is been transferred by the robot from the elevator to multiprocessor.
support-elevator-robot.fsm
yi_jing_l
Hi @gilbert jerald,
Thank you so much!
