How to combine different items in a combiner?
SRmariog09
SRmariog09
[ FlexSim 24.1.0 ]
How can I make a combiner take out the objects every so often, regardless of whether he has obtained the entry targuet? Let me explain, pallets constantly enter the combiner and boxes also enter. I want you to combine 5 boxes on a pallet, but if the time comes to take something out through the output, send what you have had time to combine, whether 3 boxes or none, and have the pallet with that come out of the output. combination.
¿Cómo puedo hacer para que un combiner saque los objetos cada cierto tiempo, independientemente si ha conseguido el targuet de entradas? Me explico, al combiner entran pallets constantemente y también entran cajas. Quiero que combine 5 cajas en un pallet, pero que si llega el momento de sacar algo por el output, que envíe lo que le haya dado tiempo a combinar, ya sean 3 cajas o ninguna, y que por la salida salga el pallet con esa combinación.
Un saludo y muchas gracias
joerg_vogel_HsH
@Mario García López, And this is not a feature of a combiner library object. You can add a logic to update several involved variable nodes to interfere with reaching values of components list recipe demand. But I recommend to build a custom process flow processor yourself to implement your procedures.
