how to code old expresions such as "setnodenum" and "setvarnum"
jose_ignacio_mn
jose_ignacio_mn
[ FlexSim 19.1.0 ]
Hello everyone,
I was used to used flexsim in past vesions and I have recently come back. As I can see, flexscript has changed a little bit and I have some questions about its new code.
I would like to use the expression "setnodnum(node,value)" and "setvarnum(object, var, value)" but I can see that now they are deprecated. I see that they still work anyway but I would like to get use to the new code. I have looked to the guide but I find it a little bit unclear to me (it says that I should use treenode.value). Could anyone help me? thanks in advance!
Thanks a lot in advance
joerg_vogel_HsH
to set
Node.value = 1.2;
to get
double myVar = Node.value;
joerg_vogel_HsH
The new dot syntax is a bit longer for variables
obj.attr.variables.subnodes[“variable_name”]
or
obj.attr.variables.subnodes[num node_rank]
Matthew_Gillespie
In 19.2 we added some variable methods to the Object class:
obj.setVariable("maxspeed", 5);
double speed = obj.getVariable("maxspeed");
Matthew Gillespie
FlexSim Software Developer
