How to check the order of relationships made between objects?
lilian_fonseca
lilian_fonseca
[ FlexSim 16.0.1 ]
Let's say I created a production line and I don't remember in which order I connected the objects between each other anymore. Is there any easier way to visualize the ordered links relationships rather than looking at the many red and green arrows that are created in the space model?
Matthew_Gillespie
If you double click on an object and bring up its properties you'll find a Ports panel on the General tab that shows what objects are connected to it.
The Input ports will show you the upstream objects and the Output ports will show you the downstream objects.
Matthew Gillespie
FlexSim Software Developer
lilian_fonseca
That is exactly what I was looking for! Thank you so much!
