- Mute
- Permalink
- Report
[ FlexSim 22.2.2 ]
Is it possible to display or check the device name in FlexSim?
[ FlexSim 22.2.2 ]
Try to catch the name by c++
https://learn.microsoft.com/en-us/windows/desktop/api/Winbase/nf-winbase-getcomputernamea
Hi @Patryk, was Joerg Vogel's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
I've played a bit with code like the following:
string cmd = programdatadir()+"gethostname.bat";
string hostfile = programdatadir()+"hostname.txt";
fileopen(cmd, "w");
fpt("hostname > \""+hostfile+"\"");
fileclose();
runprogram(cmd);
fileopen(hostfile, "r");
string hostname = filereadline();
fileclose();
return hostname;It isn't ideal. It works best if FlexSim is running with elevated privileges. If not, sometimes it takes running it twice to actually read the hostname from the written file.
It also flashes a black command prompt window, and sometimes makes FlexSim lose window focus.
If anything, it is a starting point to discover maybe a better way of doing it.
Joerg's C++ suggestion might be the best way. You could encapsulate the functionality you need in a DLL, then call it from FlexSim and get the value directly, rather than the above workaround writing and reading to files and launching a command prompt.
Good luck!
